Hi All,
I'm having an issue accessing both the results of a survey and the survey itself. When trying to access the Analyze tab in Survey123 I receive the "Cannot get necessary XForms file for the survey" warning, and the Data tab fails to fully load (just has the loading symbol infinitely). Strangely, I can access the results through the link generated in the Collaborate tab.
The survey points to a specific layer on an AGOL map, with the records in the survey populating a related table. Existing records are displaying without issue.
When trying to access the form, Survey123 says I do not have the required access. The survey has been shared correctly. The template of the survey has been used countless times before without issue, so the XForm should not have changed aside from the URL to the feature service.
If anyone has experienced any issues like this would love to hear from you!
