I’ve been using Survey123 to track our Lead Service Line inventory, and I recently noticed an issue. Some of the data collected by the team using the app does not appear at the actual inspection address. Instead, all the points are showing up around our office location.
Our town does have some cell connectivity challenges with several dead zones, but I assumed that once the inventory was collected and the device connected to Wi-Fi, the points would sync to the correct inspection location.
If these points are stuck at my office location, is there an easy way to relocate them to the correct addresses? Or will I need to start an edit session and manually drag each point to its proper location on the map?
My gut tells me I’ll need to do the manual edits, but I’m hoping there’s a faster solution. Any advice or tips would be greatly appreciated.
Thank you in advance for your help!
Todd
