Hallo everybode, I have tried two days and did not find any solution. I'm well experienced with ArcGIS Pro and have already created WebMaps, but at this stage I think I am missing something.
My task is simple, I have a polygon layer with 3 attributes (all numeric but different units and value ranges)
I want to publish this layer and have the user select the attribute and a symbology assigned to it.
In ArcGIS Pro I can just duplicate the layer, set my three styles, put them into a layer group and make it mutually exclusive so only one layer is shown at a time (hope the attached gif works). When I export his to a web map, only the currently visible layer is used.
I tried to define different styles in ArcGIS online (but failed to have several in parallel), also checked for possibilities in the Instant App, the Experience Builder and the WebMap Classic, but none of them allows me to have only one attribute displayed at a time.
I do not want to have all three attributes shown in parallel with simple checkboxes where the user has to turn one off when another one is turned on. I'd like to have some kind of radio checkboxes for the three styles or any other solution that works.
If someone has an idea, I'd be glad to hear it. But please no suggestions unless you know it works, I really tried everything and this is either not possible or I'm not doing it in the right order.
Best greetings and thank you in advance
Andy
