Hi there,
Preface information: I have an inspection in Survey123 for inlets and manholes and it is conditional based off of what the inspector selects at that first question.
I am building a map for use in field maps where an inlet or manhole can be selected, and I was wondering if I can use different links in those pop-ups where it will select inlet or manhole accordingly in the survey. I do have these set to also tie into the asset IDs, but I want to attempt to minimize errors in the field where the wrong asset could be selected in Survey123, and also make our inspector's lives as easy as possible.
I have seen (on Google AI of all things) that this is possible by using &field:inspection=MH in the link where "inspection" is the field in the survey to be completed and "MH" is the name of the option in the select_one; but I can't find an actual source to back this up, or whether or not it's supposed to be {MH} instead.
Any help is greatly appreciated 😊
