I have an existing Survey (web form) that did not have this issue in the previous version of Survey123, but after upgrading to version 3.23 web form, on most browsers on some devices, refuses to use my orgs published geocode services and will only use the Esri World Geocoding Service. I am using the same published geocode services from my ArcGIS Server that had worked previously in the Survey and that currently work fine in our other Esri applications when accessed internally or externally on Chrome, Edge, Safari, etc.
In the Survey123 designer I have each of the geocode services setup in an Address component on my form.
Hoping someone else has recently experienced this behavior and has a solution around it.
