Hi Everyone
I'm trying to troubleshoot survey123 field app working with an offline map loaded as mmpk. The users complained about excessively slow map response and I have not been able to determine if it is something with the survey or the app or if it just isn't going to work.
- With wireless access, the map and survey work fine and the map is very responsive (as expected)
- With cell service but no wireless, the map is achingly slow (10+ min to update map view when user zooms or pans to new area), even when the device is turned on for several minutes to allow update of all satellites
- In Airplane mode, the map does not open at all -sometimes the blue point icon shows on a gray background and other times the blue icon does not show. I've tried tapping home and the device location and I get the same thing
From what I have read, (e.g. https://doc.arcgis.com/en/survey123/get-started/faqgetanswers.htm#anchor17:~:text=no%20GPS%20signal%3F-,Although,-location%20sharing%20in) the survey with offline map should work regardless, (in airplane mode, with cell service only, or with cell and wireless). However there are other posts (e.g. https://community.esri.com/t5/arcgis-survey123-questions/geopoint-not-working-in-airplane-mode/m-p/879937 ) where users have had issues with airplane mode, but no solutions were suggested.
When testing, the map works fine with cell and wireless access (airplane mode off). When I turned airplane mode "on", I tried 2 mmpks and all that shows is a blank gray screen. In this case, there are no satellites - the satellite icon has an exclamation point over it.
If I have airplane mode "off", and look at the map, it responds well. Then if I turn ON airplane mode, the map is okay until I try to move and then it never shows.
I've attached the entire xls form in case something in it is the issue, but I don't think it is.
Specs:
- Survey123 field app version 3.22.58; Connect version 3.22.49
- 2 mmpk files, each are only 200kb.
- The entire folder in My Survey Designs is only 3mb.
- satellite icon shows that satellites are detected
- Using Samsung Galaxy Tab A7 lite, all up to date
- Camera and locations allowed
- location permission allow all the time, and use precise location is on
Thank you for any suggestions, or even if someone can at least tell me that this is what is supposed to happen so I can stop looking.
Peg
