Create a simple solution to copying symbology from one layer to another.
Currently in Survey 123 when you share a survey and it creates a "view" layer, the symbology is not copied across from the default symbology of the hosted feature layer. As submitters to the survey see the view layer in the website and not the actual layer, it means having to manually update the symbology in the definition tab each time you share a survey.
Either having the default symbology created in the visualization tab copy across when creating a view layer, or having the ability to copy using tool in AGOL would save so much time.
The current workaround of going into the rest service and updating the definition isn't suitable for all users Solved: Copy Symbology form one ArcGIS Layer to Another - Esri Community
