I have created a Survey123 form that contains several fields with the appearance type of 'numbers'. When one of these fields are selected in the app it is causing the screen to flicker a few times. Data can be added to the field and the rest of the form functions as expected but there appears to be a potential bug causing this to happen. This has been replicated by different users on different devices.
I also re-opened a previous form that was created that contained a numbers field and found the same behaviour (even though I'm sure this wasn't the case when this form was originally created).
If this could be looked into, I would be really grateful.
