Hello!
I am trying to modify an existing Survey I created for tracking lost or found pets in my region. However, some reports are well outside our range and so I am trying to create a geofence through Connect desktop app. I downloaded the original survey from AGOL into connect and added the fields and followed the directions from this post here: https://community.esri.com/t5/arcgis-survey123-blog/limiting-extent-in-which-a-point-can-exist/ba-p/893878.
When I try to save the Excel doc I got the following error after adding in the fields,
"There has been a problem trying to replace ${ValidX} with the XPath to the survey element named 'ValedX'. There is no survey element with this name."
I've attached a copy of the xlsx.
Any help would be greatly appreciated!
