With newly updated or published surveys, when you open the web form in edit mode, the map centers on the location that you have set in your map in Connect, not at the geopoint of the selected asset. The lat lon fields show the correct lat lon, and the pin is indeed on the geopoint, however the map is centered on the default location.
I have tested this with multiple surveys, multiple browsers, multiple platforms with the same result.
I have tried setting the default answer to null as well as a dozen other things and get the same result.
I downloaded the latest version of Connect yesterday, this occurs in AGOL and our Portal
