Is this step of the documentation correct -- select the zoning layer instead of the layer that likely has the data one wants? Here: Configure the dashboard—ArcGIS Urban | Documentation, Import existing metric values Section, Step 3.a (see screenshot attached).
Also, the instructions regarding working with metrics in the Global manager vs the plan and project UIs is confusing and incomplete. If you can point me to resources providing complete information and instruction that would be helpful. I've seen the standard documentation, here Configure the dashboard—ArcGIS Urban | Documentation and here User interface items—ArcGIS Urban | Documentation.
There seems to be some confusion over whether on can ONLY import existing pop, household, and job data, or one can import existing conditions data for each metric one will be using. The functionality of setting up metrics suggests the latter but illustrations focus on pop, hh, and jobs. Would you please clarify?
I'm trying to complete an initial deployment of AGU, and simply want to set up the model-wide metrics in the Global Manager so they bring the relevant and standard information into the plans and projects metrics subsequently created when users use AGU.
Thank you,
Scott
