Hello everyone,
I am developing a form with survey123 connect and I have a doubt. The form needs to receive data that comes from a Google Sheet spreadsheet that is updated from time to time, this data is stored in without coordinates, it only has the addresses with which I hope to run the esri World Geocoding Service to approximate its location and later update with field output the exact location.
My question is: What method do you recommend to integrate the google Sheet spreadsheet with the survey with survey 123 connect?
This is something new for me, as I have usually only created simple forms, I look forward to your recommendations. I am also open to using ArcGIS Field Maps if it is easier to create the workflow there.
Thank you very much in advance.
Regards
