Hi I am trying to use pulldata(@layer) from an ArcGIS online Neighborhood feature data layer to obtain the neighborhood based on the location provided by a geopoint question. I started with a select one question but it would be easier to select from the existing layer than to create a file of the list of neighborhoods.
I can't seem to get the pulldata to work even though I copied the syntax exactly. There is no error but the neighborhood isn't coming up.
pulldata("@layer","getValueAt","attributes.NeighborhoodName","${layer_url}","${location_xy}")
I don't see what I'm doing wrong. I just started with Survey123 connect so I may be missing something.
I'm using ArcGIS Survey123 XLSForm Template – Advanced, Template version: 3.18, Revision date: 13 June 2023
