I've two issues for the attached survey appeared in the web form :
1- I set a repeat count value for "additional_location" Repeat with a field value but the plus sign (+) appeared in the web form as attached image.
2- I tried to put a constraint for the "actual_trees_number" Field to be equal the value of "tree_sum" Field which equal the sum of "Planted_number" Field in the repeat, unfortunately the value of the sum don't appear in the web form also.
Any solution?
AG.
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
