The survey has several linked mobile map packages connected/linked to it. I have downloaded 2 different packages to my phone. When out of cell service (on airplane mode), the survey opens fine, I start collecting data, then when I go to click on the map/location button, the app crashes and closes. It does not crash when I select location from the top right icon, just when I select the location/geopoint from within the survey. There is no issue with the survey itself.
I've already contacted ESRI help/support. Just seeing if someone else has had the same problem.
