I'm using Unity 2021.3.19f1 with SDK version 1.1.0
Alike both this post and this one, I'm unable to get OAuth2.0 working in my Unity editor.
I peeked inside the ArcGISEditorOAuthAuthenticationChallengeHandler.cs to see:
private Task<string> HandleChallengeInternal(string authorizeURI)
var matches = Regex.Matches(authorizeURI, @"redirect_uri=([^&]*)", RegexOptions.IgnoreCase);
var redirectURI = matches[0].Groups[1].Value;
if (redirectURI == "urn:ietf:wg:oauth:2.0:oob")
return Task.FromException<string>(new ArgumentException("\"urn:ietf:wg:oauth:2.0:oob\" is not a supported redirect URI"));
try
var uri = new Uri(redirectURI);
if (uri.Scheme == "http" && uri.Host == "localhost")
redirectURI = uri.ToString();
else
return Task.FromException<string>(new ArgumentException("Invalid redirect URI"));
catch
Noticing that only a http://localhost URL would be allowed for the redirect URI. Now I'm unfamiliar with OAuth2.0 and new to ArcGIS, so maybe I don't understand the point of the redirect URI, but this seems odd? Am I not redirecting back to my application (as with a Unity Deeplink)? Or is it suppose to redirect to our private data on our server? Also, isn't it supposed to open my default browser for login details? Currently it does not, alike one of the posts I linked above.
My end goal is that we are able to load data layers (3D scenes and such) hosted on our server that are private. While the API key works to load a basemap fine, these private data layers need proper OAuth configuration.
So far, the best point I can get to is a "Authentication Failed" error as it is unable to retrieve info from my private server.
Apologies in advance for any misunderstandings or if I missed some documentation somewhere.
