I have a database being utilized in Field Maps as a base / master layer. I am using Survey123 to create a maintenance history by referencing the master layer from Field Maps. The referencing ID is the "Serial Number". In some instances we have Serial Numbers with symbols leading the ID. When the symbol occurs there is no data transferred into the Survey123 maintenance dataset, also any field following are blank. Is there a work around for this or a solution? The symbols are necessary and right now we are just going back and backfilling the data.
