I have created a survey form with survey 123 connect which for one asks the user to supply the location of the project they completed with a geopoint. Everything looks as it should, it publishes, and even latitude, longitude, and county "subregion" fields auto-calculate based on a function that uses the geopoint field. My test surveys submit, but when I try and bring the layer into a map viewer I have no points, no geometry. The kicker is that when I open the feature layer in ArcPro the points are visible.
Has anyone seen anything like this and have a solution. Hopefully one that doesn't require me to recreate the survey link url as it has already been given to partners.
