H
Hello can someone advice please. I cant insert row and the insert function is not visible? This survey duplicated from another survey can this be a problem? Do I need to update my original survey and it may works?
Ohh sounds like you did a regular copy paste or Ctrl-C? Bad news in 123. Always use Paste Values or all the formulas will be a mess.
Best thing now is to start over really.
Always use paste values in Excel esp with 123. The linking thing will get you all the time.
Sometimes my xlsform in Excel 365 will randomly freeze. I have to use Task Manager to close it, then reopen it. I have no idea why it does this, but that's the only solution I've found. It's more an Excel issue than Survey123 as far as I can tell.
thanks I think the survey123 wants me to break links and if I do that I will loose the date. I guess that if I use the example of survey/dublicate there some issues,. the message I am getting is that the survey links to external source and cant be updated
I think you are correct thanks for that will pencil that down
Is there really no other work around? I have even created 3 new forms (a master and 2 others that point to its feature layer) and the problem is persisting. I broke the links which the form was not dependent upon and no joy.
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
