A survey has been created in ArcGIS Survey123 connect, the sruvey contains repeats and selection questions.
In one of select_one type of question the choice name and label are in uppercase. When a user tries to send the survey obtains an error. The log is attached.
We discovered that the problem was associated with choices in capital letters. When we changed one of the choices of only one question for lowercase, It was possible to send the survey.
Is there any problem with using uppercases in choices when the survey is created in ArcGIS Survey Connect?
