The documentation is pretty clear for opening a Survey123 form from a different app like Collector/Field Maps, and push attributes from them to Survey123. I see some documentation for opening another app from Survey123 through something like (which is my current work flow):
<a href="arcgis-collector://?itemID=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX">Launch Collector To GPS Lateral</a>
What I want to know is it is possible to open Field Maps (or Collector) from Survey123, and push over attributes from Survey123 to a yet to be collected feature in Field Maps and then collect the geometry from an RTK receiver? The idea is why retype attributes if you don't have to in field maps. Here is what I would like to do from the current link I have set up from a note field (see example above that works currently) in Survey123:
<a href="arcgis-collector://?itemID=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&field:inspectiondate_dt={inspectiondate_dt}&field:siteaddress_txt={siteaddress_txt}&field:contractor_txt={contractor_txt}&field:typeinspection_so={typeinspection_so}&field:sewersize_so={sewersize_so}&field:sewersizeother_txt={sewersizeother_txt}&field:sewermaterial_so={sewermaterial_so}&field:sewermaterial_so={sewermaterial_so}&field:watersize_so={watersize_so}&field:watersizeother_txt={watersizeother_txt}&field:watermaterial_so={watermaterial_so}&field:watermaterialother_txt={watermaterialother_txt}&field:itemplotted_txt={itemplotted_txt}&field:tracerwire_so={tracerwire_so}&field:depth_txt={depth_txt}&field:generalcomments_txt={generalcomments_txt}">Launch Collector To GPS Lateral</a>
