I have been working on a Survey for our Utilities department, I have set up several CSVs that are hosted in ArcGIS Online to give them information based on the Asset ID they put in, it's separate CSVs for the different asset types they use just to keep the lists a little more organized.
For several of the CSVs this works seamlessly (as far as I can tell) with the pulldata expression filling in the address values no problem. However in one of the other CSVs this only works with some IDs, I can't identify why, the CSVs follow the same format. The fact it loads sometimes tells me the set up is still accurate, it just doesn't find the Asset IDs in the latter half of the CSV for some reason?
Has anyone experienced anything similar recently?
