I have a report template that loads perfectly well as a template in Survey123, but where I have a statement to display my geoshape on a map, in the report which is produced, I simply see the word 'true', no map, no geoshape. I have tried with and without setting a custom basemap, along with other parameters, but get the same result.
I have tried:-
${polyarea | size:300:400}
and
${polyarea|mapSettings: “4b3e8c05f2d842e094f3d1d4b18b306c”| size:840:1190}
I have also noticed that the map/geoshape does not appear in the data panel in Survey123 website, although it does appear on the map.
Having run numerous tests, I feel it must be to do with a setting in the survey itself, because the map appears if I create a new survey from my xls and use the same report template.
Any ideas anybody?
Thanks for any help.
Regards
Cheryl
