It would be helpful for my team to create default export parameters for different layouts in the same project. Typically we have two layouts, one map series that drives our assessor map publication, and an internal before / after map using a standard layout. Our workflow involves exporting from both layouts for each map change. We have to change the export parameters back and forth depending on which layout we're exporting from. It would be helpful if we could assign defaults to each layout, reducing the changes required for each export.
Thanks!
