Hi all,
I am trying to expand an existing survey by adding a repeat, which should add a related table to the feature layer. I can easily add the repeat in survey123 connect and hit the publish button only to become notifyed that I would lose all my current data, but the survey's current hosted feature layer data and service ID should not be altered.
So far I followed this guide: https://support.esri.com/en/technical-article/000023485 which brought me to the insight, that I can create a NEW feature layer with all my data, but I would need to keep my service ID (unless I did / understood sth. in the wrong way?). So this seems to be no option.
I have also read through this lengthy post: https://community.esri.com/t5/arcgis-online-questions/adding-related-table-to-arcgis-online-feature-layer/td-p/252845/page/7 but I am not even sure I understood everything discussed there. Seems to me that manipulation of the JSON file might work out. Is this the only way forward?
All the best,
Merlin
