Hello!
I created a Survey123 survey using Survey123 Connect (version 3.12.232). The survey is aimed at capturing tree data within plot areas. The plots are defined by a plot center and four plot corners. In the survey, I have created these all as geopoints, each of which has an associated horizonal accuracy that is pulled from the GPS data. Screenshot1.jpg shows the Survey123 Connect geopoint of the plot center. Screenshot2.jpg shows the first two plot corner points (there are two others just like them not shown). I will also attach the Excel form for reference. I also have geopoints for every tree within the plot as a repeat.
I just used this survey to collect some data in the field, and when I download the data to a GDB, only the plot center geopoint and the trees repeat geopoints are contained as point feature classes in the resulting data. The four plot corner geopoints are seemingly nowhere to be found (Screenshot3.jpg). However, when I look back at the survey in the app on my phone, the geopoints are clearly there (Screenshot4.png). Likewise, when I look at the data on survey123.arcgis.com, I can see the four geopoints as well (Screenshot5.jpg). So, the data clearly exist, but for whatever reason they are just not making it through to the end as a point feature class.
I'm really hoping there is some way to recover these point locations, and would appreciate any help/guidance as to how I might make that happen. Thanks!
