Hi -
I've built a survey in Connect (3.12) and I'm having trouble with one part of it. My end goal is to have the survey PREVENT submission if a geocoded address field (${matchaddress} is null. Seems easy right? I thought I could create a select_one yes/no ${validaddress} field, calculate it to be 'no' if ${matchaddress} is null and 'yes' if ${matchaddress} is not null, and put a constraint on this field so that it will not let the user submit a record if ${validaddress} = 'no', but it doesn't work. It lets me submit a record even if the matched address is null and validaddress is no. I've also tried various iterations of this using ${matchaddress} = null, since it should have the same result. No dice.
What's weird is that if I put ${matchaddress} = 'null' in the relevant column, the ${validaddress} field either shows or doesn't show exactly as it should. So why isn't the constraint working the same way? I've worked on this for days and days and I feel crazy and I'm really hoping someone on the Survey123 team can briefly work with me and take a look. I'd prefer to email my XLS rather than share here.
Thank you!
