Store bookmark in cookies
2542
7
11-28-2017 07:39 AM
ADITYAKUMAR1
Can anyone help me with the storage of map extent in cookies in ArcGIS JavaScript 4.x?
I am not able to store the extent in cookies.
Aditya
ThomasSolow
You might be better off using localStorage for this.
var extents = [...] // pretend this is an array of extents
// turn our array into a string.
// we can only store strings in localStorage
var stringifiedExtents = JSON.stringify(extents.map(extent => extent.toJSON());
// store in local storage
localStorage.setItem("myBookmarks", stringifedExtents);
// read from localStorage
function readBookmarks(){
  try {
    var extentArray = JSON.parse(localStorage.getItem("myBookmarks"));
    // use the Extent.fromJSON method to get an Esri Extent from
    // the JSON you stored.  This is the way to do this in 4.X
    return extentArray.map(extentJSON => Extent.fromJSON(extentJSON));
  } catch(e) {
    console.warn("Could not parse bookmark JSON", e);
RodrigoFelga
Can you provide some sample of your code? How you are trying to store the data in cookies? Have you tried to call toJSON of the extent and then stringfy that data to store?
ADITYAKUMAR1
Hi Rodgiro,
  As of now I am not storing it in cookies. Its just as provided by one of my friend .
function bookmarkEvent(evt) {
if (domClass.contains(evt.target, "esriAddBookmark")) {
var bmTable = dojoQuery(".esriBookmarkTable")[0];
var item = domConstruct.toDom('<div class="esriBookmarkItem" data-extent="' + sceneview.extent.xmin + ',' + sceneview.extent.ymin + ',' + sceneview.extent.xmax + ',' + sceneview.extent.ymax + ',' + sceneview.extent.spatialReference.wkid + '"><div class="esriBookmarkLabel">New Bookmark</div></div>');
domConstruct.place(item, bmTable, "last");
on(item, "click", bookmarkEvent);
on(item, "mouseover", addMouseOverClass);
on(item, "mouseout", removeMouseOverClass);
return;
Aditya Kumar
ThomasSolow
  try {
  } catch(e) {
ADITYAKUMAR1
Here is code on which I am working. I am able to store the code in local storage but not able to pull the data.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Bookmarks - 4.5</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
<script src="https://js.arcgis.com/4.5/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.bookmark-container {
position: absolute;
top: 100px;
left: 15px;
padding: 1rem;
background: #ffffff;
border-radius: 4px;
border: 1px solid #eeeeee;
box-sizing: border-box;
.esriBookmarks {
width: 100%;
position: relative;
.esriBookmarkTable {
border-spacing: 0;
border-collapse: collapse;
.esriBookmarkItem {
padding: 5px 10px;
width: 100%;
border: 1px solid transparent;
height: 36px;
cursor: pointer;
.esriBookmarkItem > *{
pointer-events: none;
.esriBookmarkLabel {
position: relative;
float: left;
overflow: hidden;
line-height: 26px;
white-space: nowrap;
text-overflow: ellipsis;
text-align: left;
vertical-align: middle;
margin-left: 0;
user-select: none;
.esriBookmarkHighlight {
background-color: #e2f1fb;
*, *:before, *:after {
-moz-box-sizing: border-box;
-webkit-box-sizing: border-box;
.esriAddBookmark {
color: #6e6e6e;
</style>
<script>
require([
"esri/Map",
"esri/WebScene",
"esri/views/MapView",
"esri/views/SceneView",
"dojo/dom-class",
"dojo/query",
"dojo/on",
"esri/geometry/Extent",
"dojo/dom-construct",
"dojo/cookie",
"dojo/domReady!"
], function(
Map,WebScene, MapView, SceneView,domClass, dojoQuery, on, Extent, domConstruct,cookie
var webScene = new WebScene({
portalItem: { // autocasts as new PortalItem()
// create the scene view
var view = new SceneView({
container: "viewDiv",
map: webScene,
environment: {
lighting: {
directShadowsEnabled: false
var bookMarkItems = dojoQuery(".esriBookmarkItem");
bookMarkItems.forEach(function(bookMarkItem){
on(bookMarkItem, "click", bookmarkEvent);
on(bookMarkItem, "mouseover", addMouseOverClass);
on(bookMarkItem, "mouseout", removeMouseOverClass);
function addMouseOverClass(evt) {
domClass.add(evt.target, "esriBookmarkHighlight");
function removeMouseOverClass(evt) {
domClass.remove(evt.target, "esriBookmarkHighlight");
if (domClass.contains(evt.target, "esriAddBookmark")){
var bmTable = dojoQuery(".esriBookmarkItem")[0];
var item = domConstruct.toDom('<div class="esriBookmarkItem" data-extent="' + view.extent.xmin+','+view.extent.ymin+','+view.extent.xmax+','+view.extent.ymax+','+view.extent.spatialReference.wkid + '"><div class="esriBookmarkLabel">New Bookmark</div></div>');
//console.log(view.extent.xmin);
var extents = [];
extents.push(view.extent.xmin,view.extent.ymin,view.extent.xmax,view.extent.xmax,view.extent.spatialReference.wkid);
var stringifedExtents = JSON.stringify(extents);
console.log(extentArray);
return;
var extArr = evt.target.dataset.extent.split(",");
// console.log(evt.target.dataset.extent);
view.goTo(new Extent({xmin: extArr[0], ymin: extArr[1], xmax: extArr[2], ymax: extArr[3], spatialReference: {wkid: parseInt(extArr[4])}}),
{duration: 2000});
</script>
</head>
<body class="calcite">
<div id="viewDiv">
<div class="bookmark-container">
<div class="esriBookmarks" id="bookmarks">
<div class="esriBookmarkList">
<div class="esriBookmarkTable">
<div class="esriBookmarkItem" data-extent="-12975151.579395358,3993919.9969406975,-12964144.647322308,4019507.292159126,102100">
<div class="esriBookmarkLabel">Palm Springs, CA</div>
</div>
<div class="esriBookmarkItem" data-extent="-13052123.666878553,4024962.9850527253,-13041116.734805504,4050550.280271154,102100">
<div class="esriBookmarkLabel">Redlands, Ca</div>
</div>
<div class="esriBookmarkItem" data-extent="-13048836.874662295,3844839.127898948,-13037829.942589246,3870426.4231173764,102100">
<div class="esriBookmarkLabel">San Diego, CA</div>
</div>
</div>
</div>
<div class="esriBookmarkItem esriAddBookmark">
<span style="float:left; line-height:26px; padding-right: 4px;" class="esri-icon-plus" aria-label="add icon"></span>
<div class="esriBookmarkLabel">Add Bookmark</div>
</div>
</div>
</div>
</div>
</body>
</html>
RobertScheitlin__GISP
Aditya,
   Here is what you are wanting:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      position: absolute;
      top: 15px;
      left: 65px;
      padding: 1rem;
      border-radius: 4px;
    .esriBookmarks {
      width: 100%;
      position: relative;
      border-spacing: 0;
    .esriBookmarkItem {
      padding: 5px 10px;
      width: 100%;
      height: 36px;
      cursor: pointer;
    .esriBookmarkItem>* {
      position: relative;
      float: left;
      overflow: hidden;
      line-height: 26px;
      text-align: left;
      margin-left: 0;
      user-select: none;
    *:before,
    *:after {
    .esriAddBookmark {
      color: #6e6e6e;
  </style>
  <script>
    var extents = [];
    require([
      "esri/Map",
      "esri/WebScene",
      "dojo/dom-class",
      "dojo/query",
      "dojo/on",
      "dojo/json",
      "dojo/domReady!"
    ], function(
      Map, WebScene, MapView, SceneView, domClass, dojoQuery, on, Extent, domConstruct, JSON
        map: webScene,
        environment: {
          lighting: {
      readBookmarks();
      bookMarkItems.forEach(function(bookMarkItem) {
          var item = domConstruct.toDom('<div class="esriBookmarkItem" data-extent="' + view.extent.xmin + ',' + view.extent.ymin + ',' + view.extent.xmax + ',' + view.extent.ymax + ',' + view.extent.spatialReference.wkid +
          extents.push(view.extent);
          return;
          xmin: extArr[0],
          ymin: extArr[1],
          xmax: extArr[2],
          ymax: extArr[3],
          spatialReference: {
          duration: 2000
        try {
          if(!extentArray){
            return;
          extentArray.map(function(extentJSON){
            var theExtent = Extent.fromJSON(extentJSON);
            extents.push(theExtent);
            var item = domConstruct.toDom('<div class="esriBookmarkItem" data-extent="' + theExtent.xmin + ',' + theExtent.ymin + ',' + theExtent.xmax + ',' + theExtent.ymax + ',' + theExtent.spatialReference.wkid +
          //return extentArray.map(extentJSON => Extent.fromJSON(extentJSON));
        } catch(e) {
  </script>
</head>
  <div id="viewDiv">
            <!-- <div class="esriBookmarkItem" data-extent="-12975151.579395358,3993919.9969406975,-12964144.647322308,4019507.292159126,102100">
            </div>
            </div>
            </div>
          </div> -->
        </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
ADITYAKUMAR1
Thanks a lot Robert, this is what I was looking for.
Aditya Kumar
Great,  then don’t forget to mark this question as answered.
