Compose MapView ignores isAttributionBarVisible=false
262
04-26-2024 06:54 AM
dev4567
Context
Using
com.esri:arcgis-maps-kotlin-toolkit-geoview-compose:200.4.0
Issue
MapView(
  isAttributionBarVisible = false
Attribution bar is still shown.
Hacky Solution
@Composable
private fun rememberAttributionBarVisibility(): Boolean {
    // must be true by default - value must change to be applied
    var isAttributionBarVisible by remember { mutableStateOf(true) }
    SideEffect {
        // fix attribution bar is not hidden by default
    return isAttributionBarVisible
Shubham_Sharma
After some more investigation, it seems like this is happening with older compose versions. Could you try updating to a more recent Compose BOM version (2024.01.00 or above)?
Shubham_Sharma
@dev4567 The MapView should be able to work with your original approach by passing in an isAttributionBarVisible to the MapView
Check out the Display Composable MapView sample app, I'm able to toggle the attribution bar.
Could you provide more context on the Composable layout you are using and how exactly is the MapView being used?
Shubham_Sharma
dev4567
I confirm it works, thanks! The error occurred on 2024.03.00, but with 2024.05.00 it seems to be fine.
