POST | All, I'm a newbie - Be nice!Is it possible to create a buffer widget and have the resulting buffer able to export to ... by mkauth_wardgetz New Contributor II 0 0 | 0 | 0 | 112 | |
POST | Hello Community , I am new to experience builder and i am currently working on a demo .I would want to know if a text... by KwabenaDenteh1 New Contributor II 0 1 | 0 | 1 | 117 | |
POST | Hello all,I hosting arcgis experience builder apps on an azure web app service. I have a custom widget that requires ... by RoderickPerendy New Contributor III 0 2 | 0 | 2 | 201 | |
POST | I have an application that has filter widgets that interacts with the map on the page. The client would now like to b... by RezaTehranifar2 New Contributor III 0 4 | 0 | 4 | 215 | |
POST | We have migrated all our apps to EB from WAB but it is crucial we have the ability to split line features which is no... by cpete225 New Contributor 0 0 | 0 | 0 | 157 | |
POST | I would like to provide a list of maps for the user to choose the map where the layer will be added.1) In the setting... by lmotta_ibama New Contributor III 0 5 | 0 | 5 | 292 | |
POST | For non-public scenes, WAB applications could send the portal application "App Id" to the portal,via "appId" in the c... by MichaelLev Occasional Contributor III 1 1 | 1 | 1 | 191 | |
POST | When developing, sometimes I get "no item" error message in the server terminal.How can the server be programmed to p... by MichaelLev Occasional Contributor III 0 0 | 0 | 0 | 143 | |
POST | I use several custom widgets in a folder which has in it the special manifest.json file,with the special line "type":... by MichaelLev Occasional Contributor III 1 0 | 1 | 0 | 176 | |
POST | Hello,There have been times when users have asked me if they could save their own version of visible layers in an exp... by PartyPelican New Contributor II 2 4 | 2 | 4 | 359 | |
POST | I am looking to customize the look of tables. Ideally, I'd like to add fill to rows by an attribute. Has anyone tried... by KateDoughty1 New Contributor III 2 0 | 2 | 0 | 197 | |
POST | Currently, EXB developer settings pane does not have Action Tab for coordinates widget and image widget.How do I "upg... by MichaelLev Occasional Contributor III 0 0 | 0 | 0 | 169 | |
POST | I use 2 custom widgets,one is a copy of esri's original coordinates widgetand the other is a copy of esri's original ... by MichaelLev Occasional Contributor III 0 0 | 0 | 0 | 178 | |
POST | I build exb web apps with exb 1.13 developer editionI need to add <script> tag to the html built by the developer edi... by MichaelLev Occasional Contributor III 0 1 | 0 | 1 | 232 | |
POST | I develop on EXB 1.13 Developer Edition.I want that WITHOUT appending "?locale=he" to the end of the application's ur... by MichaelLev Occasional Contributor III 0 0 | 0 | 0 | 179 |
User | Count |
8 | |
3 | |
2 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 |
