Sewer utility network mapping
215
05-01-2024 11:02 PM
Angiex__1
I am trying to manually map the geometric network of sewer network with Utility network, but there are some geometric network feature classes i dont know what to assign them for the asset group and asset type.
the geometric network feature classes,
1. Diesel generator sewer (pt)
2.head shaft (pt)
3.Inclusion point sewer network.(pt)
4.Release Point sewer (pt)
5.Terminal Chamber (pt)
6.ventilating column (pt)
7.Compressed air pipe (line).
If you could help me pick the correct asset group and type, it would be much helpful, because i am unable to find an SME for sewer and also if anyone who had worked in sewer utility network would be much helpful.
MichaelParma
Hi Angie,
These appear to be related to vertical assets. Esri's foundational model is directed more toward the linear assets and so you'd need to extend the model to include these. The only ready match I see is Release Point sewer -> Sewer Device/Outlet/Effluent Discharge.
Hope this helps,
Mike
Angiex__1
Thank You Mike I think right now i can do is add these assets in the Domain. Since I cant be waiting for the next release of the versions.
