ArcGIS QuickCapture- Dynamic Choice Lists- Enterprise Portal Data Causes Error
208
04-26-2024 02:11 PM
Amanda__Huber
MVP Regular Contributor
We appear to have found an issue with dynamic choice lists that use data coming from ArcGIS Enterprise. When opening a project using enterprise data for a dynamic choice list we get the error "Invalid project". When switching to AGOL hosted we don't see any issues.
 Is Enterprise data supported for this functionality or only ArcGIS Online Hosted data?
Amanda Huber
JohnathanHasthorpe
Hi Amanda,
I can confirm the enterprise layers work with dyanmic choice lists.
Are you able to share the problem project with me?
Happy to check it out.
QuickCapture@esri.com
Thanks
John
Amanda__Huber
Hey @JohnathanHasthorpe ,
Thanks for your response. I'll email you and follow up with the info.
Amanda
JohnathanHasthorpe
Hi Amanda
The issue is that the online item used in the dynamic query is referncing a ArcGIS Server Service. This is not supported in ArcGIS QuickCapture. We will add a check to the designer to make sure such layers can't be selected.
Thanks
John
