Create a parcel fabric from existing region coverages
257
8
a month ago
EddieQuinlan1
New Contributor II
I have parcel data still being maintained in Arc/Info coverages.  Within the coverages are cogo_arcs, polys, points, parcel_poly, lot_poly, block_poly, subdivision_poly, PLSS_poly, right of way_poly.  All the regions are built with the underlying polygon(s) and arcs, and are topologically correct.  Essentially, this data model was the predecessor to parcel fabric.
How do I get all the regions, arcs, polys into a parcel fabric?  Most documentation is based on a parcel poly or arcs being imported and then built into other feature classes.  My data already has the topology which I need to retain in the parcel fabric as parcels, lots, blocks, subdivisions, etc....
I've experimented with importing the parcel region into a test parcel fabric and that went well, but I don't know how to bring the other regions over and maintain the topology/connection in the fabric environment.
BillFox
MVP Frequent Contributor
AzatShagiakhmetov2
You can model lots, blocks, subdivisions, etc. as separate parcel types.
Add Parcel Type GP tool adds a new parcel type to parcel fabric. It creates 2 feature classes (first for polylines and second for polygon) and adds them to parcel fabric topology. Then you can import data directly to polyline/polygon feature classes using ArcGIS Pro generic tools, such as Append.
EddieQuinlan1
New Contributor II
I've done the first part of your comment.  I then used "create parcel type" for the next layer "subdivisions".  Here's where it gets confusing.  I used append to import my sub coverage into the subdivision parcel fabric.  Is this the correct procedure?  If so, does the topology between parcels and subdivisions remain intact?
anna_garrett
Occasional Contributor III
you may have to take all of your coverages and convert them into simple feature classes first to do clean up. that's what I had to do when we migrated to the arcmap version of the parcel fabric. we still had a ton of densified arcs that needed clean up (still do, I did not catch them all).
going from editing in arc/info to pro might be easier for you though. the core set of pro fabric tools are really reminiscent of arc/info tools.
EddieQuinlan1
New Contributor II
Thanx Anna.  Yes i've already imported the coverage into a file.gdb for processing into the parcel fabric.
anna_garrett
just to try and help answer the question to azat - if it was topologically correct in the coverage, it should remain so. the import process doesn't move anything.
BillFox
what happens with true curves / COGO information?
anna_garrett
those should be retained as long as there's fields in the attribute table? distance/direction/radius etc
