Layer List Widget Expand 1 Level
4411
8
05-27-2016 08:14 AM
JohnLucotch1
New Contributor II
Good Morning,  Has anyone had success expanding the Layer List Widget by 1 Level so the sublayers of a map service are only showing?
RobertScheitlin__GISP
John,
  Here is the solution:
open the LayerListView.js and find the layerTitleTdNode click event (@ line 272) and add these lines after it @ line 279
If you want to change this for all apps you produce in the future then change this file: client\stemapp\widgets\LayerList\LayerListView.js
If you want to change on specific app then change this file:server\apps\[app#]\widgets\LayerList\LayerListView.js
Lines 10 - 17
      //bind event
      this.own(on(layerTitleTdNode,
        'click',
        lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          imageShowLegendNode,
          layerTrNode,
          tableNode)));
      if(level === 0){
        setTimeout(lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          layerTrNode,
          tableNode), 300);
John,
Lines 10 - 17
      //bind event
        'click',
        lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          layerTrNode,
          tableNode)));
      if(level === 0){
          this._onRowTrClick,
          layerInfo,
          layerTrNode,
          tableNode), 300);
AndrewNiederhauser1
New Contributor III
Hi Robert,
I'm using WABDE 2.6. I tried to insert the code you suggested (line 213 instead of 279) but am seeing the Layer List widget now completely blank/empty. Any suggestion you can provide would be greatly appreciated. Below is screenshot of the code in my LayerListView.js. My goal is to expand only the first/initial level of the map service and not the subsequent/all groupings.
Andrew
Andrew,
   It looks like they changed a variable name again. Change your line 217 from imageShowLegendNode to imageShowLegendDiv.
AndrewNiederhauser1
New Contributor III
That did it. Thank you Robert!
MatthewFletcher
This still works in V2.20, add the code after line 351.
KeithAnderson
New Contributor III
On a similar note:
I added Line 7 to emulate the click event on the Popup - Expand All Layers
        lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          imageShowLegendDiv,
          layerTrNode,
          tableNode)));
            this.foldOrUnfoldAllRootLayers(false);‍‍‍‍‍‍‍
GeorgeKatsambas
Occasional Contributor III
In WAB Developer 2.7 does this code change work?
