change on-panel widget's location and size in foldtable theme
4659
7
11-19-2015 02:02 PM
LefterisKoumis
Occasional Contributor III
This question was asked before, last year by another user, of how to change the size of an on-panel foldable widget and got no working answer. Hopefully, someone has a suggestion.
I tried to modified the config.json, but it seems the theme overrides it
"widgetPool": {
    "panel": {
      "uri": "themes/FoldableTheme/panels/FoldablePanel/Panel",
    "widgets": [
  "label": "mywidget",
  "uri": "widgets/mywidget/Widget",
  "position": {
          "left": 55,
          "top": 45,
   "height":300
  "index": 3
and I tried the panel manager
var pm = PanelManager.getInstance().getPanelById(this.id + '_panel');
         pm.resize({h:300});
and it still doesn't work.
Can we change location and size of the widget in the foldable theme?
RobertScheitlin__GISP
Lefteris,
  I would require some editing in the [install dir]\server\apps\[app#]\themes\FoldableTheme\widgets\HeaderController\Widget.js. Keep in mind that this will affect the apps responsive design for mobile:
Add lines 16 - 29
_showIconContent: function(iconConfig) {
        if(iconConfig.inPanel === false){
          this.widgetManager.loadWidget(iconConfig).then(lang.hitch(this, function(widget) {
            this.openedId = iconConfig.id;
            var iconNode = this._getIconNodeById(iconConfig.id);
            //we don't call widget.startup because getWidgetMarginBox has started widget
            //widget.startup();
            html.setStyle(widget.domNode, 'zIndex', 101);
            this._setOffPanelWidgetPosition(iconNode, widget);
            this.widgetManager.openWidget(widget);
        }else{
          if(iconConfig.position){
            if(iconConfig.position.width){
              iconConfig.panel.position.width = iconConfig.position.width;
            if(iconConfig.position.top){
              iconConfig.panel.position.top = iconConfig.position.top;
            if(iconConfig.position.left){
              iconConfig.panel.position.left = iconConfig.position.left;
            if(iconConfig.position.right){
              iconConfig.panel.position.right = iconConfig.position.right;
          this.panelManager.showPanel(iconConfig).then(lang.hitch(this, function(panel) {
            this.own(aspect.after(panel, 'onClose', lang.hitch(this, function() {
              this._onPanelClose(iconConfig.id);
And in the main config.json add the position object to your desired widget:
"position": {
          "left": 105,
          "top": 45,
          "relativeTo": "map",
          "width": 450
Lefteris,
  I am able to change an on screen widget (the ones in the 1, 2, 3, 4, 5 placeholders) by adding a width property to the position property of the widget in the config.json.
        "position": {
          "left": 105,
          "top": 45,
          "width": 200
        "placeholderIndex": 1,
        "id": "_29",
        "name": "Bookmark",
        "label": "Bookmark",
        "version": "1.3",
        "uri": "widgets/Bookmark/Widget",
        "config": "configs/Bookmark/config_Bookmark.json"
The position of the widget (on screen widget) is always going to be relative to the on screen widget button position.
LefterisKoumis
Thank you Robert.
Yes, I can do that for an on-screen widget.
My question is for the foldable theme only and for on-panel widgets.
The code shows the widget is under the widget pool block.
I am trying to manage the size and location of a on panel widget that is on the foldable theme.
I can change the on-panel widget location and size  on other themes.
Is anything in the documentation that refers to these limitations for this theme?
Thank you.
Lefteris,
  OK you are going to have to help me understand what you are referring to as on-panel widget... Are you taking about the widgets in the header controller that popup on the right side of the screen?
LefterisKoumis
Yes, that's correct. Sorry for not been clear. I thought the code provided showing the widget under the widgetpool would indicate its type.
Thank you.
Lefteris,
Add lines 16 - 29
            //widget.startup();
        }else{
"position": {
          "left": 105,
          "top": 45,
          "width": 450
LefterisKoumis
Fantastic! Thank you!. Otherwise, the widget as setup by the default foldable theme looks like a side panel.
LefterisKoumis
Robert,
I noticed that the height is not included in your code, so I added it. However, I cannot modify the widget's height in the config.json. Can the height be modified? Also, can the widget be floated around after its initial location is set?
Thank you.
widget.js
   if(iconConfig.position.height){
              iconConfig.panel.position.height = iconConfig.position.height;
config.json:
"position": {
          "left": 105,
          "top": 45,
          "width": 450,
    "height":300
