POST | I develop WAB 3D apps (with custom widgets) for our enterprise.I need a that the app Javascript code will detect if a... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | 102 | |
POST | I develop WAB 3D apps (with custom widgets) for our enterprise.In a few cases I want my WAB app to load private layer... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | 94 | |
POST | My wab app uses 3D scene and many private feature layers.This web app runs on my enterprise and is used by closed peo... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | 91 | |
POST | In my custom widget I need to draw some parallel lines inside polygon,so that each of them will not go outside the po... by MichaelLev Frequent Contributor 0 1 | 0 | 1 | 378 | |
POST | Editor widget can modify editable feature layer attribute values.Can I modify them also directly by javascript?If yes... by MichaelLev Frequent Contributor 0 0 | 0 | 0 | 348 | |
POST | Editor widget should show only editable layers and only if they are visible.in API 2.24, it behaved so.But in API 45.... by MichaelLev Frequent Contributor 0 1 | 0 | 1 | 448 | |
POST | Has anyone created a custom Query widget or Search widget with query? I am new to this community. Any help would be ... by ebachilo New Contributor 0 1 | 0 | 1 | 460 | |
POST | Hi,We developed a custom Google Streetview widget for one of our web appBuilder applications and it is working well. ... by SailiTang_HW Occasional Contributor 0 0 | 0 | 0 | 713 | |
POST | I am building a portal in which I need to display information on a timeline in this way: https://nasa.github.io/edsc-... by YERSON_STIVENGALINDO_HUESO New Contributor 0 0 | 0 | 0 | 470 | |
POST | my scene is 3d containing buildings etc.I want to create polygon that its points will "stick" to the 3D scene and not... by MichaelLev Frequent Contributor 0 1 | 0 | 1 | 839 | |
POST | I develop 3D web apps by web appBuilder using ArcGIS API forJAvascript 4.24AreaMeasurement3DViewModel draws orange-wh... by MichaelLev Frequent Contributor 0 1 | 0 | 1 | 722 | |
POST | I have been testing out some street view widgets that have been posted in this group and I noticed one that was worki... by shildebrand Frequent Contributor 3 1 | 3 | 1 | 1122 | |
POST | Hi everyone,We have recently deployed ArcGIS Enterprise 10.9.1 and are looking into adding custom widgets to Web AppB... by shildebrand Frequent Contributor 0 3 | 0 | 3 | 1156 | |
POST | In Enterprise 10.9.1...Has anyone been able to customize the attribute table widget to auto refresh whenever the map ... by ChrisBerryman Regular Contributor 1 1 | 1 | 1 | 528 | |
POST | I develop custom widgets on ESRI WEB AppBuilder (developer edition)I want to use the library "maker.js" for building ... by MichaelLev Frequent Contributor 1 0 | 1 | 0 | 593 |
