Hello
I have converted a Geometric Network to a Trace Network and published it to Enterprise. If I bring it back into Pro then I can use it as expected i.e. I can trace using its TraceNetwork REST end point. I would like to let all users make use of this within an Experience Builder application.
I notice that the Analysis widget in Experience Builder in ArcGIS Online now had the ability to connect to a GP task. Has anyone tried to publish the a Trace Network trace as a GP and run it from Experience builder?
My test data is not external facing so I cannot test it out with ArcGIS Online.
Thanks.
Yes, I tried to do this but couldn't get it to work. Esri has said that the widget only supports utility networks.
