Barriers in list in Trace Locations Pane don't flash, pan, or zoom
369
09-01-2023 01:40 PM
JaneSchafer-Kramer
New Contributor II
ArcGIS Pro 3.1.2  - data stored on network drive. In the Trace Network (not utility network) I have added barriers onto the NHDFlowlines manually using the Add features tool in the Trace Locations Pane. When I right click on any barrier in the list and click on flash, pan, pop-up, zoom, select, or unselect, nothing happens.   Any ideas?
JonDeRose
Good morning,
I am unable to reproduce this behavior with a trace network in 3.1.2 or 3.1.3.  If there are current TN_Temp_Starting_Points and TN_Temp_Barriers feature classes in your project's default geodatabase,   could you test deleting these and recreating them by placing the trace locations again to see if the issue persists.
JonDeRose
Good morning,
