David,
I would suggest using R to do the analysis of your points and then plotting the result in ArcMap to make the Map. If you are more fluent in using the ESRI's R-bridge than I am, you may be able to figure out a way to do this from within ESRI. Below is a link to a paper which may help. The paper I think is by Prof. C. Brunsdon at University of Leicester. The paper focuses on trying to find out how car ownership varies across the country (England) and uses the centroid (x,y) coordinates of zones where people live as data points. The paper is based on Fotheringham et al. (2002) Geographically Weighted Regression: The Analysis of Spatially Varying Relationship, published by Wiley. Now that said, your ability to do this will depend on your familiarity with R. The attached paper was written some time ago and refers to an earlier version of R which may not be quite the same as the current version of R. So, you may encounter some difficulty lining up the script in the paper with the current version of R. This can cause frustration, but I encourage you to try as you will learn a great deal in the process and improve you Spatial Statistics skills dramatically. R is an excellent tool to know well if your work has you doing a great deal of statistics, spatial or otherwise.
http://www.bristol.ac.uk/media-library/sites/cmpo/migrated/documents/gwr.pdf
Best Wishes, Bill Meyer, US Army Corps of Engineers - ERDC Champaign
