Calculating Local Moran's I
1152
05-24-2021 03:02 AM
Peer
Hi!
I am trying to understand the calculations behind Local Moran's I and I was wondering how the mean (X bar) was calculated. I think I understand the consept of neighbourhood and the weight matrix, W, but what the corresponding attributes mean is not clear to me. Do you include the value of i in the mean or du you leav it out of the equation?
Any help would be great, thanks!
LaurenGriffin
X bar is just the mean. If you are running Local Moran's I on a variable X, then X bar is the mean for all X values. I don't remember if the mean is computed as sum of all X values divided by N or the sum of all X values divided by N-1, though. If you locate the tool in the system toolbox, you can right click on it and select Edit to see the tool code.
I hope this helps!
Best wishes,
Lauren
JoshG
Hi Lauren - I tried right clicking on the tool and selected Edit but I got a pop-up box that says the Script File is empty. Is there any other way to view the tool code?
LaurenGriffin
What version of the software are you using? (It shouldn't matter, but I can try to reproduce what you're seeing). This is what I'm seeing:
In the Geoprocessing pane, I select Toolboxes. In The Spatial Statistics toolbox under Mapping Clusters, I right click on the Cluster and Outlier Analysis tool, select Edit, and up pops the script.
Another way to find it is to navigate to: <your ArcGIS folder, where ever you installed the software... like maybe in ProgramFiles\ArcGIS> then navigate to: \Pro\Resources\ArcToolBox\Scripts and view the LocalMorans.py python script file. For example, you should be able to right click that file and choose open with <Notepad or Wordpad, for example>
I hope this works for you!
Best wishes,
Lauren
JoshG
Hi Lauren, thank you for the instructions, they worked! I was trying to find the tool by searching the tool box instead of accessing it in the way you suggested.
