find closest facilities
559
01-02-2018 02:34 PM
ChuckRoberts
How to I set parameters in ArcGIS Pro to find nearest facilities and show drive times? I need to also determine where I input the starting point, i.e. "show all post offices within a 10 minute drive time of x".
DanPatterson_Retired
are you trying to follow or emulate the closest facilities tutorial?
ChuckRoberts
This looks along the lines of what I need Dan. I hadn’t seen the tutorial before, so let me give that a try. Thanks!
ChuckRoberts
Hi again,
I am unable to successfully connect to the training data and display. After connecting to the transportation folder and attempting to “drag and drop” the data into the map, I receive an error message (attached) about upgrading my ArcGIS metadata.
Chuck
don't drag and drop stuff... especially the part about the template
Did you follow these instructions from the first page?
Get the data
The data for this tutorial is available for download on arcgis.com.
  1. Go to the item description web page of the Network Analyst tutorial data on arcgis.com.
  2. Click Open > Download, and save the file locally.
  3. Unzip the downloaded file.
Create a map
  1. Open ArcGIS Pro.
  2. Create a new project based on the Map.aptx template.
    A new project with a map appears.
ChuckRoberts
Hi Dan, yeah, I was trying to add in the street network data as per the attached snapshot…
