I pulled data that I collected using Survey123 from the cloud by using the R-bridge; I needed to perform quality control for some attributes. During my QC, the datetime field was not touched. Now, I am using arc.write to save my final product in a feature class on a local GDB, but then I note that while the dates are correct, the time is showing like the process of saving added 6 hrs.
So, for example, my first survey record started at 14:42 PM, and this was correct before I saved the feature dataset. After saving, ArcGIS Pro, indicates that the same record was collected at 20:42 (8:42 PM). How can I preserve the correct time? Is there any argument within arc.write() that I need to set?
