Change any of the Basemaps to grayscale?
1402
08-17-2017 07:56 AM
NicholasLiccini
New Contributor II
Hi!
I'd like to be able to change the ArcGIS basemaps to be grayscale so that it is easier to see graphics drawn on there. I'm aware of the lightGrayCanvas basemap, but I'd also like to have the imagery basemap be grayscaled. Is this possible?
Thank you!
LucasDanzinger
Esri Frequent Contributor
You can modify the brightness, contrast, and gamma on the client side, as ArcGISTiledLayer inherits from ImageAdjustmentLayer - ImageAdjustmentLayer QML Type | ArcGIS for Developers
You would need to loop through the layers in your Basemap, and apply the values that you want to each of the layers in the Basemap. Maybe you can combine these properties to get an output that is to your liking.
LucasDanzinger
