You should be able to do this still. Here is some code that should get you on the right track:
import QtQuick 2.6
import QtQuick.Controls 2.2
import QtQuick.Layouts 1.3
import Esri.ArcGISRuntime 100.7
ApplicationWindow {
width: 800
height: 600
title: "Untitled123"
property bool mouseAccepted: !freePanButton.checked
property var startPoint
property var endPoint
MapView {
anchors.fill: parent
focus: true
GraphicsOverlay {
Graphic {
SimpleRenderer {
SimpleFillSymbol {
outline: SimpleLineSymbol {
color: "red"
width: 2
color: "transparent"
onMousePressed: {
mouse.accepted = mouseAccepted;
startPoint = mouse.mapPoint;
onMousePositionChanged: {
endPoint = mouse.mapPoint;
envBuilder.setCorners(startPoint, endPoint);
graphic.geometry = envBuilder.geometry
Map {
BasemapTopographic {}
EnvelopeBuilder {
spatialReference: map.spatialReference
ColumnLayout {
RadioButton {
checked: true
text: qsTr("Free Pan")
RadioButton {
text: qsTr("Draw Rectangle")
