Unable to use the 64 Bit Arcpy modules to list table or print records or do anything on a non sde geodatabase where as the same code works absolutely fine with 32 Bit arcpy modules.
Doing this simple process and I'm stumbled to understand why this is not working in 64 Bit
import arcpy
# Set the current workspace
table = 'D:\\abc\\xyz.sde\\user.table'
if arcpy.Exists(table):
print "Exits"
Got all the TNS Entries configured tried different versions using single slashes, double slashes etc but no luck in 64 Bit.
Using ArcGIS 10.6.1 with ArcGIS Oracle 18 C Patch.
