Setting expression and code block as a script tool parameter when calculating field
1273
14
10-04-2023 09:45 PM
JasmineSpring
New Contributor III
Hello
I am having trouble is my script tool to set the parameters for the expressions and the code block. Is this something that is possible? If it is, to check Im adding the paramters correctly what do I need to specify? (ie data type, direction)  Thank you so much for your help!
import arcpy
POAlayer = arcpy.GetParameterAsText(0)
POAexpression = arcpy.GetParameterAsText(1)
POAcode = arcpy.GetParameterAsText(2)
# Calculate field
arcpy.management.CalculateField(POAlayer, "POA", POAexpression, "PYTHON3", POAcode)
2 Solutions
BlakeTerhune
MVP Regular Contributor
@JasmineSpring wrote:
Thank you so much !  I am trying to test the calculation with the null values already = 1 as below. I get the error NameError: name 'poa_fields_expr ' is not defined
The variable on line 11 needs to be renamed.
import arcpy
# Get the selected layer
# Create a list of field names starting with "poa"
poa_fields = [field.name for field in arcpy.ListFields(layer) if field.name.startswith("poa")]
 # Use the Field Calculator to calculate the product
poa_fields_expr =  " * ".join([f"!{field}!" for field in poa_fields])
expr = f"my_calc_func({poa_fields_expr})"
# *args allows any number of arguments to be passed into the function.
code = '''def my_calc_func(*args):
    result = 1
    for poa_value in args:
        result = result * poa_value
    return 1 - result
arcpy.management.CalculateField(layer,"Product_poa",expr,"PYTHON3",code)
JasmineSpring
New Contributor III
Thank you Blake ! Very much appreciated. That works perfectly. Below is the final solution
import arcpy
for field in poa_fields:
    with arcpy.da.UpdateCursor(layer, poa_fields) as cursor:
        for row in cursor:
         row = tuple([1 if v is None else v for v in row])
         cursor.updateRow(row)
    result = 1
    return 1 - result
    in_table=layer,
    field="Product_poa",
    expression=expr,
    expression_type="PYTHON3",
    code_block=code
BlakeTerhune
I don't see why it wouldn't work. Seems easy enough to test as-is though. Can you clarify what you're having trouble with?
JasmineSpring
New Contributor III
Thanks for your help. Im having troubles to try to define the parameters in the tool to make it work right.
I couldnt find the data type option that made it work.
thank you !
BlakeTerhune
Does it work if you define POAexpression and POAcode as String?
AlfredBaldenweck
To your original post, I'd suggest
POAlayer = arcpy.GetParameter(0)
 to return a layer object instead of a string, and see if that fixes it.
JasmineSpring
New Contributor III
I used the parameter for the input layer as a layer. Thank you !
JasmineSpring
New Contributor III
Hi ,
I am trying another way to do this using  update cursor and field calculator unsuccessfully.  I am wanting to change the null values of selected fields in feature class and multiply these fields and subtract them from 1 with the results in a new field. Thank you for you help
import arcpy
    for row in cursor:
      if row[0] is None:
         row[0]="1"
expression = "1" if not poa_fields else " * ".join([f"!{field}!" for field in poa_fields])
arcpy.CalculateField_management(layer, "Product_poa", expression, "PYTHON")
BlakeTerhune
Please fix the indentation in this code.
Shauna-RaeBrown
#JasmineSpring, one thing you need to do after using any cursor, is you need to del the cursor.  Your code should look something like this...
import arcpy
      for row in cursor:
         if row[0] is None:
            row[0]="1"
del cursor
 (see line 15).
JasmineSpring
New Contributor III
Thank you for your reply
I altered as above and the tool runs but the field doesnt calculate the product_poa field. Maybe the error is in the expression? I would like the field in the list to multiply and then be subtracted from 1.
eg . 1 - (field *field*field)
The fields being taken from the list.
Thank you very much
