Python Script to Disconnect all users from a database
6756
05-09-2014 10:21 AM
BenDrury
I am not very Python savvy...  trying to develop a script to disconnect all users from a 10.2.2 SDE database.  Can anyone tell me what I'm doing wrong?
import arcinfo
import arcpy
# Variables:
sde_TestServer = "\\\\computer\\c$\\Users\\user\\AppData\\Roaming\\ESRI\\Desktop10.2\\ArcCatalog\\sde@TestServer.sde"
#Disconnect Users
arcpy.DisconnectUser ("sde_TestServer", "ALL")
THANKS!
JoshuaChisholm
You are python savvy Katherine! You're only missing one thing: take the quotes away from sde_TestServer. Like this:
import arcinfo
import arcpy
# Variables:
#Disconnect Users
arcpy.DisconnectUser (sde_TestServer, "ALL")
The reason: if python sees "sde_TestServer" it reads it as the string "sde_TestServer". If python sees sde_TestServer it looks for a variable that was previously set using that name.
AimeiChen
Hi, Josh
Id like to have this handy tool as well. But I was running into an error, says Connection information provided was for a non-administrative user. But the user "msdgc" can disconnect user from ArcCatalog.  would you please help, thanks!
Amy
import arcinfo
import arcpy
# Variables:
sde_Server = "c:\\Users\\user\\AppData\\Roaming\\ESRI\\Desktop10.1\\ArcCatalog\\msdgc@msdtest.sde"
arcpy.DisconnectUser(sde_Server, "ALL")
  File "C:\Program Files (x86)\SystemScheduler\disconnectuser.py", line 8, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\__init__.py", line 1040, in DisconnectUser
    return gp.disconnectUser(sde_workspace, users)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Connection information provided was for a non-administrative user
BenDrury
Are you using a SDE user Connection to establish this? It needs to be either the SDE user or possibly the SA user for it to work properly, preferably the SDE user
AimeiChen
I switched to SDE user but still got same error message. Thanks!
AsrujitSengupta
Does the sde user have "processadmin" fixed server role?
