Having trouble with a function that converts dates between date and text type
365
09-10-2024 10:27 AM
jacob_ekn
I made a script tool that takes in table data from another team, performs an XY table to point, does some analysis, then outputs a final feature class with fields all formatted and in the right order. This was all working fine until it came time for updates and the XY table to point tool started changing some of the date fields in the Excel table to a different type than the original table that we have hosted on AGOL (we use the Update Data function in AGOL with the newly created/updated feature class from running the tool).
To try to fix this, I created a function that creates a new field for each date, checks the type, and calculates the new field to be the correct type based on the original table (the hosted feature layer).
Here's the function:
def date_verify(in_table, in_field, out_field, ver):
    date_func = '''
    function GetDate(date_text) {
        var date_list = Split(date_text, '/');
        var y = Number(date_list[2]);
        var m = Number(date_list[0]) - 1;
        var d = Number(date_list[1]);
        return Date(y, m, d);
    function GetString(date) {
        return Text(date, "MM/DD/YYYY");
    field_calc = f'''
    {date_func}
    var val = $feature.{in_field};
    if (IsEmpty(val)) return null;
    else return Get{ver}(val);
    temp_type = [f.type for f in arcpy.ListFields(in_table) if f.name == in_field][0]
    curr_type = "Date" if temp_type == "Date" or temp_type == "DateOnly" else "String"
    ver_type = "TEXT" if ver == "String" else "DATE"
    if (ver != curr_type):
        arcpy.management.AddField(in_table=in_table, field_name=out_field, field_type=ver_type)
        arcpy.management.CalculateField(in_table=in_table, field=out_field, expression=field_calc, expression_type="ARCADE")
    else:
        arcpy.management.CalculateField(in_table=in_table, field=out_field, expression=f"return $feature.{in_field}", expression_type="ARCADE")
    return
I keep getting an Index Out of Bounds error specifically from the GetDate function in the Arcade expression, and based on the line in my script where it keeps happening, it seems that the conditional (on line 30 here) is being met when it shouldn't. Is there something I'm missing? Or is it possible to get XY Table to Point to get all the field types correct so I don't have to bother with this in the first place?
TonyAlmeida
Maybe try,
    if (IsEmpty(date_text)) return null;  // Added a check for empty values
    // Ensure the list contains exactly three parts (month, day, year)
    if (Count(date_list) != 3) return null;  // Added a check to prevent Index Out of Bounds
jacob_ekn
I do have a check for empty values on line 22. It seems the issue is that the conditional in the if on line 30 is returning true in instances where it would be expected to return false and I can't figure out why.
TonyAlmeida
This will help you see if the dates are being parsed and formatted correctly.
    if (IsEmpty(date_text) || !Contains(date_text, '/')) return null;
    if (Count(date_list) < 3) return null;
    // Debug output
    return Text(Date(y, m, d), "MM/DD/YYYY");
