I'm using beautifulsoup to scrape a list of URLs for Covid-19 info which in turn is used to update our ArcGIS Hub page. Once in a while, a URL is broke and I get a bad handshake error. I want my script to handle this then move on. Currently, there is one URL in the list that is broke, and that one is causing the error(s) here. I tried the following exception block on these errors to no avail.
I also tried these approaches to no avail:
while loop
except requests.exeptions.SSLError as error:
except...
print("error")
try:
item = soup.find(string=re.compile("Grab and Go")) if
soup.find(string=re.compile("Grab and Go")) else "N/A"
print(item)
except (OpenSSL.SSL.Error, ssl.SSLError, urllib3.exceptions.MaxRetryError,
requests.exceptions.SSLError) as error:
print(error)
break
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\contrib\pyopenssl.py", line 456, in wrap_socket
cnx.do_handshake()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\OpenSSL\SSL.py", line 1915, in do_handshake
self._raise_ssl_error(self._ssl, result)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\OpenSSL\SSL.py", line 1647, in _raise_ssl_error
_raise_current_error()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\OpenSSL\_util.py", line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
During handling of the above exception, another exception occurred:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 600, in urlopen
chunked=chunked)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 839, in _validate_conn
conn.connect()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connection.py", line 344, in connect
ssl_context=context)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\util\ssl_.py", line 347, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\contrib\pyopenssl.py", line 462, in wrap_socket
raise ssl.SSLError('bad handshake: %r' % e)
ssl.SSLError: ("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')],)",)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\adapters.py", line 449, in send
timeout=timeout
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\util\retry.py", line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.cm201u.org', port=443): Max retries exceeded with url: /news_/free_breakfast___lunch_pick-up_days (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')],)",),))
File "pathtofile", line 33, in <module>
response = requests.get(url, headers=headers)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\adapters.py", line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='www.cm201u.org', port=443): Max retries exceeded with url: /news_/free_breakfast___lunch_pick-up_days (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')],)",),))
