Hi all, I'm trying to install the arcgis python library using PIP. I need to use PIP as I'm installing the library to a custom folder for a custom python 2.7.1 environment (SideFX Houdini, not to be confused with an actual python environment) not the system's python install.
This is the error I get:
c:\python27\lib\distutils\dist.py:267: UserWarning: Unknown distribution option: 'long_description_content_type'
warnings.warn(msg)
No handlers could be found for logger "root"
File "<string>", line 1, in <module>
File "c:\users\gemof\appdata\local\temp\pip-install-pztuao\arcgis\setup.py", line 267, in <module>
setup(**kwargs)
File "c:\python27\lib\site-packages\setuptools\__init__.py", line 129, in setup
return distutils.core.setup(**attrs)
File "c:\python27\lib\distutils\core.py", line 151, in setup
dist.run_commands()
File "c:\python27\lib\distutils\dist.py", line 953, in run_commands
self.run_command(cmd)
File "c:\python27\lib\distutils\dist.py", line 972, in run_command
cmd_obj.run()
File "c:\users\gemof\appdata\local\temp\pip-install-pztuao\arcgis\setup.py", line 120, in run
super().run()
TypeError: super() takes at least 1 argument (0 given)
Command "python setup.py egg_info" failed with error code 1 in c:\users\username\appdata\local\temp\pip-install-pztuao\arcgis\
Any help is appreciated!
TNKS!
G
